Hey guys... a little advice he
Old 10-20-2003, 05:39 AM
karma279
karma279's Avatar
Default Hey guys... a little advice he
I think I have narrowed down my next move. I'm going to put in 3.73's, pulleys and headers. My question(s) are: Is a Richmond gear OK? I have heard to only use Ford Motorsport... and def. not Motive. I can get a good deal on a Richmond. I also found a good deal on a set of MAC equal-length shorties. Do they bolt on as easy as some of the others? Also my factory H-Pipe has the 2 big cats removed and the 2 pre-cats gutted. Is there really a need for an aftermarket H-Pipe?</P>
karma279 is offline
Old 10-20-2003, 11:31 AM
89muscle
89muscle's Avatar
if you are gonna do them yourself and know what your doing it doesnt matter what kind you use. and richmond makes ford racing. they just buy them from them. i work at a ford dealership so. equal are alittle bhit haredr to get on than the unequal and its definatly a good idea for a new h-pipe. i got the bbk off road with no cats and it makes the car sopund nasty with the flowmasters and the bbk unequal headers. its a must. x-pipe cost alot more for 1-3 hp gain over the h-pipe. plus they sound meaner.
89muscle is offline
Old 10-20-2003, 11:42 AM
vfast
I ♥ Acer
vfast's Avatar
Richmond's are great gears...the equal lengths will tak about .5-1.0 hrs longer to put in...I would buy an h-pipe and keep the other for inspections
vfast is offline
Old 10-20-2003, 11:59 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
The main reason people choose the motorsport is because 99/100 you don't have to worry about gear whine due to improper setup of the gears. The FMS gears can virtually always just be a bolt in where as with richmond or other gears you really only want someone who know what their doing setting them up. Improper pinion depth is a bad thing </P>
Richmod is probably better than FMS but all I would ever use myself is the FMS. Also even though your cats are gutted an aftermarketh or x pipe will still flow alot better, not to mention your stock exhaust size is 2 1/4 which is quite small</P>
mdvaldosta is offline
Old 10-20-2003, 12:00 PM
karma279
karma279's Avatar
No inspections here <IMG src=smileys/smiley10.gif border="0">. So is there a better gain from equal length headers?
karma279 is offline
ak98
02-18-2023 08:36 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Hey guys... a little advice he
