help, i'm really frustrated
Old 05-19-2008, 08:39 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default help, i'm really frustrated
ok i've been workin on this for a while now (8 hours ish) trying to remove the lower control arm without destroying anything
all 4 bolts between the two control arms are seized up in their spot. i've broken two of the loose but all they do is spin in place because of the metal sleeve in the bushing is rusted to the bolt itself. i've use the following tools to try and removing the bolts. air impact (120PSI), 3 foot breaker bar, propane torch, mapp torch, drill(only on one i've drill some of the bolt out in attempt to break it out of the hole) air punch and air chisle.
out of all that i havent broken either arm free.
i figured since this is getting pretty intense that couldmake it easier on myself and cut the control arms off in half and just remove the rear end completely.
any help or tips plz let me know i'm gettin really pissed off.
FivePointOhh is offline
Old 05-19-2008, 10:21 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: help, i'm really frustrated
I had to use a sawzall on a customers car one time. Saw in between the arm and the subframe itself to cut the bolt.
AdderMk2 is offline
Old 05-19-2008, 10:59 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
cut the bolts ftw!!!
mjr46 is offline
Old 05-19-2008, 11:19 AM
67mustang302
67mustang302's Avatar
That's why I put anti-sieze on crap, so I don't have to fight with it if it ever needs to come off. Too bad they didn't do it from the factory, but they wouldn't spend the extra money on it I'm sure.
67mustang302 is offline
Old 05-19-2008, 11:44 AM
FivePointOhh
in limbo
ORIGINAL: AdderMk2
i've been doing that, "geuss i didnt put that in teh discription.
what blades are you using? i was using two different kinds. one was with serated teeth and was a carbide tip. other other kind i was using was a blade that it looks like a gritty substance was attached to the serated blade made of tungstin and carbide. neither seems to be cutting very efficiently.
what kind of blades did you use and did it take a long time?
Old 05-19-2008, 01:10 PM
bighungrymatt
bighungrymatt's Avatar
it shouldnt take long using the sawzall, get some metal blades from home depot or lowes
bighungrymatt is offline
Old 05-19-2008, 01:31 PM
FivePointOhh
in limbo
yea.....exactly what i listed in the post above yours
both are listed for metal.....neither cutting very fast.
JoshyGT
09-19-2017 08:52 PM
03blackwidow
09-20-2015 02:36 PM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
zennx
11-28-2004 01:08 AM
DreamStang
12-12-2003 02:32 PM
Quick Reply: help, i'm really frustrated
