what else could be causing the stalling?
Old 05-19-2008, 04:58 PM
1mean5.0
1mean5.0's Avatar
Default what else could be causing the stalling?
Ok guys, my tps is set perfect, egr and iac are both cleaned along with my throttle body intake and mass air and my car still stalls out when I start it in the morning. I hold about 1200 rpms for a minute or so then it is fine, what the h*ll could be causing this problem???
1mean5.0 is offline
Old 05-19-2008, 05:24 PM
xB1u3xF1v3xO
xB1u3xF1v3xO's Avatar
Default RE: what else could be causing the stalling?
my car used to the the same thing with my old engine..i thought it was just cold nature but when changed the computer and maf..it stopped...does your car do it all the time or only cold start ups?
xB1u3xF1v3xO is offline
Old 05-19-2008, 05:28 PM
sYckmYnded
I ♥ Acer
sYckmYnded's Avatar
VACCUM ISSUE!
sYckmYnded is offline
Old 05-19-2008, 05:57 PM
shaun8850
shaun8850's Avatar
Did you just do the H/C/I setup? You might need a custom tune if thats the case... Mine car did that untill I brought it in had a chip done. Your stock computer need to be calibrated to your setup, your A/F ratio could be off along with other things.
shaun8850 is offline
Old 05-19-2008, 06:09 PM
1mean5.0
1mean5.0's Avatar
yes it is only on cold start ups, I did the H/c/i almost a year ago and didnt always have the problem.
1mean5.0 is offline
Old 05-19-2008, 06:10 PM
1mean5.0
1mean5.0's Avatar
is there an easy way to diagnose a vaccum leak?
1mean5.0 is offline
Old 05-19-2008, 06:20 PM
shaun8850
shaun8850's Avatar
there are different ways to check for leaks.. fogger but if u have a manual fan it will blow all over the place, electric fan make sure its off and the smoke should get sucked in.. or triple check all connections u might have over looked something... Get a can of starting fluid and lightly spray around suspected areas, idle will rev up if it gets sucked in...
http://www.aa1car.com/library/vacleak.htm
check this out~
cr620
10-03-2022 10:18 PM
Dathan
10-05-2015 05:52 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: what else could be causing the stalling?
