cam retainer plate
cam retainer plate
im in the process of rebuilding a 5.0 and it was a roller motor... am i right in sayin that the retainer plate has got to go back even if you arent going with a roller cam??? plz no hating cause of me not going back roller... its not gonna be efi any more so im going with a voodoo solid mechanical cam 246/255@.50.; .555/.595 lift...
RE: cam retainer plate
ok thanks. i couldnt remember... i havent taken a ford cam out in so long that its pitiful. i know that on a roller chevroletblock you dont have to use it if you arent going back with a roller cam(in fact, you cant use it, the cam is 1/8" longer if its a non roller)...
in other words, just wasnt sure about a ford anymore. dont have to take them apart like chevys b-cuz they're such better motors
ORIGINAL: 1992gt400hp
o, i know^^^ i just dont want to run roller anymore. cant get the specs i want out of any roller cams i found so far.
Choosing to run a flat tappet cam over a roller cam is pointless, unless you're in a restricted racing class that requires it. Most roller cams with "smaller numbers" will perform better than an equivalant numbers flat tappet cam. And like Woody said, the numbers they publish don't tell you much about how the cam operates.
ORIGINAL: 67mustang302
