Pinion gear
Old 05-20-2008, 08:19 AM
Duspan
Duspan's Avatar
Default Pinion gear
Stupid question but, does the spline count on the pinion gear have to match the axel spline count?
Duspan is offline
Old 05-20-2008, 08:54 AM
ahittz24
ahittz24's Avatar
Default RE: Pinion gear
No the spline counts are independent of each other. You can put a different carrier or really just the spider gears in from a explorer I believe and go from 28 spline axles to 31 spline axles.
ahittz24 is offline
Old 05-20-2008, 05:40 PM
tinman
tinman's Avatar
The pinion gear spline count and the axle spline count DO NOT need be the same.
In, fact most of the time they aren't.........
tinman is offline
Old 05-20-2008, 05:45 PM
hillbilly pony
hillbilly pony's Avatar
The only time you have to worry about pinion splines is if you are upgrading the pinion yolk. Axles are completely seperate
hillbilly pony is offline
Old 05-20-2008, 07:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just put some 31 splines in and be done with it
mjr46 is offline
baddog671
07-26-2016 01:20 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Pinion gear
