bbk adjustable cable adjustment
i did my clutch about 300 miles ago and ive got to reset the toe play. last time i set the cable adjustment i ran the bbk firewall adjuster almost all the way in and then set the toe play at the transmission. now that i look back i may have been mistaken in my adjustment because sence the clutch is wearing in im getting a higher pedal and i dont have enough adjustment inwards to tighten it up. if i run theadjuster out the release point just gets higher so im assuming that you have to run the cable inwards to tighten the cable?
my otherquestion is when you set the toe play should the bbk adjustable firewall adapter be ran all the way in or all the way out?
