ultimate test for electrical mastermind
i have 89 fox...
fuel gauge does not read above approx. 1/4 tank however it wil read below that and gas light does come on when almost out of fuel
i replaced sending unit ... still doesnt work
isanded surface(s) forground wires that are inside of hatch behind trim ... still doesnt work
i took harness of fuel sender unit and grounded the signal wire which i believe should make gauge read full and did not!
any suggestions? please help!
RE: ultimate test for electrical mastermind
how you figure its broken i said it reads below a certain level...the fuel gauge does move which tells me its getting signal so im thinkin more along the lines of bad connection somewhere in between
That system is a bridge circuit with the variable on the leg with the gauge in electrical series. If you have replaced the sending unit and your power and grounds are good the little techy gnomes that live in the gauge andtranslatethe variable current to the mechanical swing of the indicator armare on strike. get a new gauge
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
