advancing timing
Old 05-22-2008, 10:18 PM
Foxbodyforever
Foxbodyforever's Avatar
Default advancing timing
12 degrees of advanced timing is fine with regular pump gas right?
Foxbodyforever is offline
Old 05-22-2008, 10:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: advancing timing
89 octane may be reccommended..but bump it to 13-14 and run high test ftw
mjr46 is offline
Old 05-22-2008, 10:39 PM
Foxbodyforever
well i wanna stick with 87 so what's the most timing i can run?
Old 05-22-2008, 10:48 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Bump it a degree or 2 at a time until she hollas and then back it off. Each car is different due to mileage, wear, carbon build up etc!
PRO50SC is offline
Old 05-22-2008, 11:43 PM
RoadsterRider
RoadsterRider's Avatar
It takes about 10 seconds to change the timing, just try it.
RoadsterRider is offline
Old 05-23-2008, 09:47 PM
mxrider426
mxrider426's Avatar
I have ming at 16 advanced on 87 octane and still no spark knock. Im actually going to try and advance it more.
mxrider426 is offline
Old 05-24-2008, 09:08 AM
imnotmy77stang
imnotmy77stang's Avatar
thats just too much.... your ending up with too much advance at the top and your going to either loose power or hurt your motor - maybe both
imnotmy77stang is offline
Old 05-24-2008, 11:39 AM
5.0 MPG
5.0 MPG's Avatar
quick question, when you advance timing is it before TDC or after TDC?
5.0 MPG is offline
Old 05-24-2008, 11:57 AM
94GTPRO5.0
94GTPRO5.0's Avatar
it is BTDC.stock is at 10* BTDC
I have a 94 GT and I have mine set at 13* BTDC
94GTPRO5.0 is offline
Old 05-24-2008, 11:59 AM
5.0 MPG
5.0 MPG's Avatar
thanks
5.0 MPG is offline
Quick Reply: advancing timing
