Lowering Problems! Help!
Old 05-23-2008, 05:37 PM
The rent man
The rent man's Avatar
Default Lowering Problems! Help!
Having a horrible time with front struts on '91 GT. Droppedwith 1" front lowering springs and spring compressors in rear a couple of years ago.Car sat perfect, at least for my taste. Put on new shocks and struts (Gabriel blue gas charged). Now the front end has shotup, rear is fine. Thinking logically, I slotted the strut bolt holes upward to allow the strut to set 1/2" lower in its mounting cradle. It didn't make any difference at all.How can I get these struts from hell to stopjacking the car up in the front???Thanks Guys [:@][:@]
The rent man is offline
Old 05-23-2008, 06:05 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: Lowering Problems! Help!
That's weird, struts shouldn't effect the height of the car. Did you install SN95 struts by chance? Also did you happen to remove the front springs at all during the strut install?
OnyxCobra is offline
Old 05-23-2008, 06:23 PM
The rent man
I didn't think they would either. I just took the ones that were suppose to be for the car.Please tell me what SN95 struts are and how I can tell. I have disposed of the boxes as I didn't expectanything like this to be an issue.
Old 05-23-2008, 06:28 PM
The rent man
No, I didn't remove the springs when I changed the struts. They were changed a couple of years ago.
Old 05-23-2008, 06:57 PM
OnyxCobra
OnyxCobra's Avatar
well are you sure the springs didn't rotate at all while u were messing around in there? If the spring rotated out of it's perch the car would sit higher for sure. I actually just saw this at the dealership i used to work at. SN95 struts are struts for SN95s, or 94-04 Mustangs. They are actually longer than fox struts so figured maybe if they were bottomed out it could be holding the car up some. Something doesn't add up though b/c struts don't effect the height of our cars.
Old 05-23-2008, 07:08 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Unless they break. Did you put the bushings back in correctly??
projectresto83 is offline
Old 05-23-2008, 07:15 PM
The rent man
That all makes sense. I assume that's why fox struts are sometimes used on later models that have been lowered. I think I'll dig out the receipt and call to make sure they gave me the right part #. I'm pretty darn sure the springs didn't move around although I'll take another look as the right is slightly higher than the left. Thank you for your response! If anyone else has had this problem please tell me what you did!!!
Old 05-23-2008, 07:53 PM
The rent man
As for the bushings, tell me if this sounds right: Top nut, big washer. rubber bushing with metal tube through it with beveled side up as other side conforms to shape on camber/caster plate, camber adj. plate, plastic dirt cover, rubber bushing on strut shaft inside dust cover. Thanks
Old 05-24-2008, 08:05 AM
projectresto83
M.A.D. Motorsports
I havn't done it personally but it sounds about right. My bushings are screwed on that side so my passenger side is dropped about a inch lower than my driver.
mtgldr
02-03-2024 09:00 PM
2007CalSpec
12-13-2020 11:42 AM
PullTab
10-30-2015 08:46 AM
Dragonus18
09-09-2015 01:21 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Lowering Problems! Help!
