HELP! Auto Meter Speedometer Install - MustangForums.com
Old 05-23-2008, 07:44 PM   #1
Fistuv
Default HELP! Auto Meter Speedometer Install
I just installed an Auto Meter programable Speedo in my 1995 GT. I have it working great. My only question is connecting the new speedo to the PCM. On the back of the speedo it has an out source that sends +5 Volt DC Square wave signal. It says this out source MAY be used as a VSS signal with some OEM ECM's and cruise control Units. What I need to know is if this signal will work for the PCM to read it correctly? Also if it will work where do I connect it to? Do I connect it to the + side(gry/blk wire)of the original 2 wire sender harness or what? Thanks for the help!
Fistuv is offline   Reply With Quote
Old 05-24-2008, 12:58 AM   #2
Fistuv
Default RE: HELP! Auto Meter Speedometer Install
any ideas at all?
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2016 Mustang 15 06-23-2016 06:26 PM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 07:46 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 09:43 PM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 09:51 PM
HELP A/C Wont blow cold, electrical 2008 cbird1177711 2005-2014 Mustangs 0 09-02-2015 05:12 PM
auto, autometer, gauge, hook, install, installation, installing, meter, mustang, spedo, speedo, speedometer, vss
