dist. question - MustangForums.com
Old 05-23-2008, 09:04 PM   #1
will
will's Avatar
Default dist. question
Will any 302 dist fit and work in any302 as long as you install the right gear to match the cam?
will is offline   Reply With Quote
Old 05-23-2008, 10:33 PM   #2
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: dist. question
Quote:
ORIGINAL: will
it'll all depends on if it's efi or carbed and ignition system used
mjr46 is offline   Reply With Quote
Old 05-23-2008, 10:50 PM   #3
will
will's Avatar
Compare the 2 dist shafts from gear to end the efi model is longer why?
[IMG]local://upfiles/22200/5A7FAE026BA94B07A487468672871B74.jpg[/IMG]
[IMG]local://upfiles/22200/BA4E428284254B73B778584FAE97A11E.jpg[/IMG]
Old 05-23-2008, 11:11 PM   #4
mjr46
mjr46's Avatar
just means more of the shaft will be seated in the dizzy..but what are you trying to do and maybe I can tell you what application you need to purchase.
Old 05-23-2008, 11:17 PM   #5
will
will's Avatar
95 5.0 carb conversion w/hei dist, I just want to be sure my oil pump will be driven correctally, I think I'm going to shove some modeling clay into the shaft end and install it...see if it pushes the clay up the shaft.
Old 05-23-2008, 11:20 PM   #6
mjr46
mjr46's Avatar
when you say HEI are you musing a GM style dizzy with integral coil in cap?? or ford duraspark set up??
Old 05-23-2008, 11:24 PM   #7
will
will's Avatar
GM style
Old 05-23-2008, 11:32 PM   #8
mjr46
mjr46's Avatar
just make sure you have a steel gear installed on the hei dizzy for a roller cam motor
Old 05-23-2008, 11:38 PM   #9
will
will's Avatar
Done that TY for your help[8D]
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 09:13 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 09:06 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 11:29 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
