Check Engine Light(HELP!) - MustangForums.com
Sponsored by:
Sponsored by:
Old 05-23-2008, 09:06 PM   #1
RoadsterRider
Default Check Engine Light(HELP!)
So I've got my 88 mustang running perfectly, it passes the actual emissions portion of the smog test easily, but I've got one thing holding me back. The check engine light comes on while it's turing over, instead of coming on when the key is turned to the "ON" position and turning off when the starter is engaged. Any ideas?
Thanks,
Cory
RoadsterRider is offline   Reply With Quote
Old 05-23-2008, 09:14 PM   #2
Joel5.0
Joel5.0's Avatar
Default RE: Check Engine Light(HELP!)
Yep..... that's normal for non-Cali '88 setups.... the CEL became "functional" in '89+ models.
Joel5.0 is offline   Reply With Quote
Old 05-23-2008, 09:15 PM   #3
RoadsterRider
It's cali(sorry, I should have specified).
Old 05-23-2008, 09:25 PM   #4
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
run a koeo/koer test and see if any codes are output if not..don't worry about it
mjr46 is offline   Reply With Quote
Old 05-23-2008, 09:26 PM   #5
Joel5.0
Joel5.0's Avatar
No prob...... checked the MIL strategy in the GUFB document for the '88 Cali strategy, and it is normal. Here's the document extract.
Quote:
Additional features of the MIL are:
1. It is disabled during VIP tests.
2. It is turned on continuously in CRANK mode until a PIP is detected as a
bulb check.
The bulb check can be disabled by setting MILLIM equal to
zero.
Old 05-23-2008, 09:27 PM   #6
RoadsterRider
Quote:
ORIGINAL: mjr46
I wouldn't worry about it if i could smog the damn thing, but as it is I can't smog it and therefore can't register it.
Old 05-23-2008, 09:29 PM   #7
RoadsterRider
So it's fine? Damnit, how do I prove that to the smog place? I might just have to take it somewhere else. DAMNIT!
Thanks for your help
You wouldn't be able to point me in the direction of some sort of proof, would you?
Old 05-23-2008, 09:31 PM   #8
mjr46
mjr46's Avatar
if they are not allowing it to be tested and don't know the foxes ecm strategy sounds like you needs to edumacte dem some!!
Old 05-23-2008, 09:54 PM   #9
Joel5.0
Joel5.0's Avatar
What MJ said...... they need to check the requirements for the year of your car, not use the existent ones and make them retroactive..... that's a loose-loose situation. Here's a snapshot of the strategy document from FoMoCo.... it should help you prove your case.
1992 Summer Edition - Wont start! labudski 5.0L (1979-1995) Mustang 2 08-24-2015 07:23 AM
crank position sensor 2004 mustang 3.9 v6 microgt V6 (1994-2004) Mustangs 2 08-20-2015 07:12 AM
dealership issue mweiland General Tech 6 08-13-2015 05:11 PM
Fuel pump not priming!! HELP drumhedd2005 2005-2014 Mustangs 2 08-13-2015 09:59 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 12:59 PM
