Strut & Caster Camber plates won't fit???
Old 05-24-2008, 08:33 PM
capri debris
capri debris's Avatar
Default Strut & Caster Camber plates won't fit???
Here's the story...
I mounted new Mac C/C plates.
Put new KYB struts in.
The top threaded rod that goes through the C/C plate was too short to get the nut on.
Called Mac and explained... they said the dust boot can't be used with their plates.
I saidwithout the dust boot, the chrome rod will get dirt on it and destroy the strut seal.
Mac said they tell people all the time that it's OK to take the boot off and have never had complaints about strut seal failure.
I saw some UPR C/C plates on ebay and thought maybe they would work with the dust boot.
So I called UPR and asked the same questions and they told me the same thing as Mac. (not to use the boot)
So I called KYB and explained the situation.
They said the boot MUST be used or the seal will fail and that KYB struts aren't meant to be used with C/C plates because the top threaded rod is shorter than stock.
I compared the KYB strut to a stock strut and sure enough, the rod is shorter.
Now, here is my question...
Does anyone have KYB gas adjust front struts (with the dust boot still on) and found a caster camber plate that will work with the short top threaded rod?
This is pissing me off and I feel like I'm getting the run around from Mac, UPR and KYB. Someone please chime in and let me know what plates will work for me. I can't return the KYB struts (too much time has passedand they've already been installed) so I NEED to find a set of C/C plates that will work with my KYB's soon.
Thanks in advance!
capri debris is offline
Old 05-24-2008, 08:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Strut & Caster Camber plates won't fit???
that may be tough to find as most caster camber plates don't allow the use of dust boot....mac and upr are correct...as for kyb.... of course they'd say that..any strut manufactorer would say that...I keep my lakewoods clean and have coilovers and for 2 years no dust boot, no leaks and or probs....there are loads of cars out there whose dust boots fell off like my wifes camry with 167000 and still going strong andd we live on a gravel road = very dusty and no leaks yet....but I haven't ever seen what your asking for availible
mjr46 is offline
Old 05-24-2008, 08:53 PM
my little red 90
my little red 90's Avatar
if your worried about it, put in some shorter springs.
my little red 90 is offline
Old 05-24-2008, 09:07 PM
capri debris
ORIGINAL: my little red 90
The car already has Vogtland lowering springs in it... that's why I need the C/C plates. Besides, the spring height doesn't change anything when it comes to how the strut mounts into the C/C plate.
Old 05-24-2008, 09:15 PM
capri debris
ORIGINAL: mjr46
You make some good points, but even if the seal doesn't wear out after running it without a dust boot, the boot has a bump stop built into it. My KYB's don't have internal bump stops and without the boot (and bump stop) if I hit a deep pot hole and bottom out the suspension, it could drive the rod down into the strut cylinder and damage it. This is quite a dilema I have and I hope someone has a solution for me... I'm stuck with my KYB's, need C/C platesand a dust boot with a bump stop.
Old 05-24-2008, 09:22 PM
mjr46
mjr46's Avatar
ORIGINAL: capri debris
ORIGINAL: mjr46
If this is the one you've done all up...I'd hate to see it hit a pot hole too!!..that's gonna be a tough one in a sense I share your dilema a little.. I just drive slow down rough roads and try to avoid any bad patches of road.. I know that's not the answer your looking for but sometimes that's what happens in the 5.0 world [:@]
mjr46 is offline
Old 05-24-2008, 09:29 PM
Tony71502
Tony71502's Avatar
Are you referring to KYB GR2 struts? Im using GR2 struts up frontwith steeda aluminum C/C plates and it was a breeze getting it installed. I didnt use the dust boot that is on top of the strut tower. I had no problems getting all the proper hardware on either.
Tony71502 is offline
Old 05-24-2008, 10:07 PM
5.0stanger
5.0stanger's Avatar
If you ae worried about the bump stop, take it out of the dust boot and put it on the strut. When I put my coil overs on, I used my stock CC plates(had to modify them) I didn't install the dust boots, but I took the bump stop out and put that on.
5.0stanger is offline
Old 05-24-2008, 11:39 PM
stang8689
stang8689's Avatar
I have KYB struts with Hotckis c/c plates. Hotchkis includes everything you need including bushings and boots. Its very high quality and is much thicker than BBK or Mac. You will be very happy with it, check into hotchkis.
http://www.mustangsunlimited.com/ite...p;CatKey=74-01
stang8689 is offline
Old 05-24-2008, 11:46 PM
stang8689
stang8689's Avatar
Its has the urethane bushings with it as well
Quick Reply: Strut & Caster Camber plates won't fit???
