Replacing fuel pump on a 91 LX
RE: Replacing fuel pump on a 91 LX
Not hard at all. Make sure you empty the take as much as possible before hand because you have to drop the tank down. Do you the precedure at all?? Sometimes it helps to have a buddy there to help but it can be done with one person pretty easy too.
drop tank = 2 traps..undo elec connection and fuel lines and slide out from filler tube and then tap locking ring around with straight blade screwdriver and hammer
yeah not that difficult to do, i used a good flat peice of plywood on top of my jack to put it back it (3/4 full) but other wise not that hard to do. only bad thing is you REEK of gas for a couple of hours
ORIGINAL: 86whitepony
ORIGINAL: sultan68
arent you supposed to use a brass punch around fuel because it won't spark
zanemoseley
09-06-2015 12:58 PM
