351?
Old 05-26-2008, 09:35 PM
droptop302
droptop302's Avatar
Default 351?
What was the last year they used a351 in?And did they use the HO fireing order? and will it clear a stock fox hood?any input will be great
droptop302 is offline
Old 05-26-2008, 09:40 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default RE: 351?
Hood clearnace can be tricky. Some people can clear some can't. It depends on your setup up top mainly. You can use convertable engine mounts because they set the engine down lower. You can also buy tubular k members that set the motor down lower too. And yes I do believe they use the H.O. firing order.
projectresto83 is offline
Old 05-26-2008, 11:10 PM
PJC Racing
PJC Racing's Avatar
Default RE: 351?
I'm pretty sure the last year for the 5.8 was 96. Yes all 351w's have the same firing order that is shared by the 5.0 H.O.. Hood clearance can be had if you order parts just keep it under the hood on a carbed vehicle with F.I. you will need at least 1.5" cowl in most cases.
PJC Racing is offline
Old 05-27-2008, 01:27 AM
67mustang302
67mustang302's Avatar
Default RE: 351?
It's actually more accurate to say that the 302HO uses the 351W firing order.
67mustang302 is offline
Old 05-27-2008, 05:27 PM
droptop302
droptop302's Avatar
Default RE: 351?
what cars or trucks used the 351?
Old 05-27-2008, 05:30 PM
88BlueGT
88BlueGT's Avatar
Default RE: 351?
broncos, f150's, some vans, etc.
88BlueGT is offline
Old 05-28-2008, 12:06 AM
dudeboy
dudeboy's Avatar
Default RE: 351?
I cleared my stock 90GT hood using a Lightning lower intake, comp cams box upper intake (the polymer one), and Energy motor mounts (I think they were Energy... not sure though).
I still had to shorten the upper box intake by .700" in order to clear... barely...
http://www.freewebs.com/vristang/fox351wswapfaq.htm
jason
dudeboy is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
teeeeg67
09-01-2015 11:53 PM
steelers743
08-31-2015 07:16 AM
Mustangs of Illinois
08-22-2015 10:00 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 351?
