How to put on a ring and pinion gears???
Is it hard to install it by myself??? Or would i just be better off taking it the the shop?? I got 4:10 for free are these pretty good!! My pops gave them to me. Also if i do take it to the shop, how much should it cost around to install it, so i won't get cheated on thanks.
RE: How to put on a ring and pinion gears???
ORIGINAL: bdptcob
Don't do it yourself. Should cost between $200 and $300 to install.
Thanks for the price and ideas. I am gonna take it to the shop. I am pretty sure i got everything. This is exactly what my dad got me that is on ebay!!
http://cgi.ebay.com/ebaymotors/Ford-...em270239799391&
I am pretty sure this is everything and is a good oem or close to it for the ring and pinion gear.
Yea it has it is the exact product it comes with all of these things that it has on the directions.
Ford Pinion Shim Kit
- Ford Pinion Nut
- Ford Crush Sleeve
That should just be all i need right!!
- Ford Pinion Nut
- Ford Crush Sleeve
those are just shims for behind the pinion.. I know what the ford racing kits come with..cause I just bought and installed a 3.73 frpp set saturday....the carrier shims that may be needed if you can't reuse stock ones and I couldn't cause it didn't give me the right backlash reading so I purchased an install kit and in such come the carrier shims needed which are different from the pinion shim kit included in your set..or just take what you got to a shop and if they do them often they may have carrier shims laying around that you may need
Damn thanks for the info, i just got to go find a shop now in san fancisco ca that does these stuff specially so they can have the part there. This sucks lol. Ohh well tell me if this one comes with everything on ebay i just found.
http://cgi.ebay.com/ebaymotors/4-10-...em300225855385&
