vibration
vibration
when i start to go say in 1st gear and the rpms start to go up the stick starts to vibrate alot and the same in the higher gears to so when i feel that vibration i shift but it seems so early to do so i get no power please help with this problem? its an 84 gt with a t5 and stock 2.73 which is gonna change soon 2.73= no power
RE: vibration
not when i let off the clutch its only as the rpms start to rise in that particular gear and when i push the clutch in and shift to the next gear its alright becuase its at low rpms but as it starts to rise in rpms u feel the vibration in the shifter
RE: vibration
some vibration is normal but make sure you don't have a broken motor mount and or tranny mount and check harmonic balancer and make sure it has not spun a little on the rubber
ccdguy
09-19-2015 05:20 PM
