%.0 Mustang Codes Pulled, need help
I have a sn95 5.0 mustang and i have maf sensor problems, i pulled the codes and code 157 and 116 came up 116 is a coolant issue and 157 is a maf problem the code said "\\; maf sensor fault, low voltage i need insight on what todo i tried cleaning it but that didnt work
RE: %.0 Mustang Codes Pulled, need help
well if i smash down the pedal it bucks (jerks me back and forth) only sometimes though, and it takes longer than it should to start also bogs at first start up. what would low voltage mean?
