Cam Suggestions 1993 GT
I was at the local speed shop today looking for some info on getting a new cam put in my 1993 GT, the guy there kind of burst my bubble. I'm looking for some serious lope, a "damn that pony is cammed" type effect. He told me because my car is fuel injected and not carbed that a high lift cam is not the path I want to go down, that my computer will have issues.
He suggested a ford racing e303 cam, saying I could slide that right in without having to beef up anything else.
I'm looking for a second opinion which is why I'm here. What are my options? Like I said I want my car to lope, what I've done tomy pony thus far is minimal including shorty headers, off road h-pipe, flowmaster cat back, and high flo air filter.
I dont mind spending a bit extra to accomodate my needs including buying rods and lifters and springs. Anything. What can I do to my car guys to get that woomp woomp woomp that I'm looking for?
Thank you all
~Sean~
Thank you all
~Sean~
RE: Cam Suggestions 1993 GT
the e303 cam woulld work fine with you computer, a b3o3 or even an f3o3 would work. the e303 is a mild cam though and has some lope to it, but not a real radical lope or anything like that. i would suggest that you get new valve springs to go along with the new cam though, but a cam only install will not really give you alot of horsepower and torque may a 10hp gain at the most. I HIGHLY reccomend that you do an intake and head upgrade at the same time as the cam install so that you will get the most out of the cam. In a lot of cases an overcammed engine on stock heads and intake can even make you car a little slower. AFR, Edelbrock, Canfeild, and TrickFlow all make good cylinder heads for a 5.0. and Holley Trickflow, and the Gt40 intakes are all real nice too. Hope this helps you out a little!
first that guy you talked to is a douche!!!......lift will not so much create a prob as an aggressive lobe profile with lots of valve overlap and duration will.. but still the eec iv is capable of self adaptation and an e-cam is old tech..there are better choices and a cam swap = valvetrain upgrage you can't just slide e in with no spring upgrade.. good thing you didn't trust him and came here first cause he's got his bass ackwards
Custom is the best if you can afford it. It can range from $300-$400.
A few options, since very forum has their favorite:
Ed Curtis (edcurtisFTI@verizon.net) @ www.flowtechinduction.com
Buddy Rawls (rawls1103@aol.com) @ http://www.wighat.com/fcr3/index.html
Jay Allen (jayallen@comcast.net) @ www.camshaftinnovations.com
They will all do a nice job for you.
If you are on a budget, go with a TFS-1 camshaft. It will not hold a candle to a custom camshaft in overall performance (not just power).
I would suggest getting a camshaft with an intake and cylinder head combination.
ORIGINAL: VASSAGO
yea letter cams are for us normal working guys that cant afford a $600+ custom grind! lol
