Rediculous Bogging problems
Old 06-06-2008, 09:21 PM
94RedDevil
94RedDevil's Avatar
Default Rediculous Bogging problems
I'm having trouble figureing this one out. Firstly, the radiator and the intake tube up to the tb was off of the car recently before the issues occured. Not really sure if that is the cause of the problem. I can get the car to start but when it does and i give it gas, it has a real delayed throttle response makes a sucking noise (not the normal one like before) then will raise the rpms and bogg down. The car cant be driven very far because it will not stay alive and boggs down really badly. After it is started several times, it doesnt want to start up again. Anyone ever had this happen before. Thanks for any help that you could give me.
94RedDevil is offline
Old 06-06-2008, 09:27 PM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: Rediculous Bogging problems
check the throttle linkage and loose sensors.
may have also broken a vac line
93 LX FiveO is offline
Old 06-06-2008, 09:29 PM
94RedDevil
94RedDevil's Avatar
wouldnt a vac line cause the motor to run at a higher rpm tho?
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
look for a leak in the air intake boot/ tear in the boot/tubing from mass air meter to tb..or a vaccum leak somewhere
mjr46 is offline
Old 06-06-2008, 10:02 PM
AdderMk2
Banned
AdderMk2's Avatar
or check to see if you even plugged the MAF back in
AdderMk2 is offline
Old 06-09-2008, 02:07 PM
94RedDevil
94RedDevil's Avatar
MAF is plugged in. I thought that there might be a leak in the tube that goes to the MAF so i undid all the clamps and reclamped them. I then sprayed w/ carb cleaner and no leaks. The car will start up and run for a long time, even drive. It boggs a little bit when you give it gas. If the car dies, it doesnt start up again until you give it time to cool. I dont get it! could anyone help me?
Old 06-09-2008, 03:08 PM
94RedDevil
94RedDevil's Avatar
bump, help me out guys
6bangr
02-15-2016 07:40 AM
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Quick Reply: Rediculous Bogging problems
