Throttle body??
Old 06-08-2008, 05:06 PM
dancam
dancam's Avatar
Default Throttle body??
I just bought a 70 mm throttlebody with spacer, for my 90' 5.0. I currently have stock manifold on it and dont know if I need to port them to match. Does anyone know what the stock manifold port size is? Thanks
dancam is offline
Old 06-08-2008, 05:22 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Throttle body??
Yes, you will. Honestly, you're not gonna see much out of the t/b on an all stock set up. What else is done to the car? Exhaust, gears? If not, that money spent would have been better served on items like those.
PRO50SC is offline
Old 06-08-2008, 05:29 PM
dancam
dancam's Avatar
I will be installing bigger injectors , I have a 10psi vortech on it now .
dancam is offline
Old 06-08-2008, 05:31 PM
dancam
dancam's Avatar
I do have 3:73 gears and exhaust done to it.
dancam is offline
Old 06-08-2008, 05:43 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: dancam
Oh OK. See it helps to know all the info when asking opinions. saves us time and trouble. What size injectors are you going up to and what mass air are you planning on running? I think the stock is 65mm.
PRO50SC is offline
Old 06-08-2008, 05:58 PM
dancam
dancam's Avatar
I was going to go with 42lbs but now i'm leaning towards 30lbs. I was told that 30lbs are good up to 430 hp supercharged and 500+ nat. aspirated. Also the 30lbs are self tunable. Do you agree?
dancam is offline
Old 06-08-2008, 06:10 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
To a point. I have 42's in mine. i had issues when running 30's. I had a custom multi tune chip burned and it pretty much solve my issues. (no need for an fmu either) Again, what mass air are you gonna run. I would recomend the p-mas 3" blow thru. Works great for me.
PRO50SC is offline
Old 06-08-2008, 08:26 PM
dancam
dancam's Avatar
vortech recommends a recalibration kit for the fmu according to which injectors you run. So I'll try that with the new injectors / mass air meter/sensor and throttle body. Hopefully it will run alright!
dancam is offline
Old 06-09-2008, 02:24 AM
rebel_yell
rebel_yell's Avatar
i just put a mac 70mm tb on my car with stock manifold I/H/E and i saw a big improvement in all ranges in torque and a medium gain of high rpm horsepower
i had a firend modify it to make it flow lust a bit better i have pics of it here. and i port match the manifold slightly but im working on gettign a new intake manifold so i didnt try so hard.
rebel_yell is offline
Old 06-09-2008, 05:17 AM
dancam
dancam's Avatar
thanks i apreciate the info
dancam is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Throttle body??
