T5 shifting question
RE: T5 shifting question
ORIGINAL: Gun Jam
when your right your right
3.00:1
whats a good gear that will keep rpm reasonable for highway speeds of 80 to 90mph? With my c4 I was turning about 3,600 to 3,700 at about 85 to 90mph if I remember correctly which was too high for my taste.
I know lots of people run the 3.55s with the t5 and im guessing thats probably about right.
-Gun
3.00:1
-Gun
okay okay ignore the cobra comment lets just call it a 1352-249
It shifts great into first with no grind at all.
According to your inputs it sounds like it working as it should.
-mjr46 do you have a diff ratio calculator that accounts for overdirive or a formula? All the ones I have seen assume 1:1
With 3.50 what would be my rpm at 90? what about with 3.73s? with a 25" rear wheel and probably a .63 overdrive.
Thanks for your help guys
-Gun
-Gun
4 th gear on the t-5 is 1 to 1 but if I understand your question right and most t-5's the overdrive is .68?? ...I don't have a diff calculator bu my guess is around 90 mph rpm's would be closer to 3000 with my old t-10 and 3.50's rpm's at highway speed were 3000 easy = to much for me so that's why I DID the t-5 conversion
ORIGINAL: Gun Jam
is there anyway to figure out if my t5 is .63 or .68 based on the tag number?
thanks
-Gun
thanks
-Gun
1352-249
Ford Mustang All 5.0 V8 WC
U
2.76
2.95
1.94
1.34
1.00
0.63
that's why it may not be as peppy in 1st and has flat spots when climbing to another gear..I have a 3.35 t-5 first and it's ample...but coupled with your 3.00 gears your ratios are not prudent to achieve what you desire......with a .2.95 t-5 and a .063 overdrive you might wanna think about at least a 3.73 gear
Yeah I knew it had the high nickel alloy gears and was the "badass" t5
so now that we know 5th is a .63 ratio does anyone know how to calculate rpm at 90 mph with a with 3.73 gears? I havent found a formula that allows for overdrive do i just take the 1:1 rpm and x by .63???
Thanks
-Gun
Thanks
-Gun
ORIGINAL: Gun Jam
Thanks
-Gun
Thanks
-Gun
I autocross my car and sometimes I have to downshift into 1st if I don't want to bog coming out of some of the sharper turns. As long as I rev match it (still working on my heel-toe) it goes in without grinding or skidding the back tires but I usually am not looking at my speedometer when I'm doing that so I don't really know what speed I'm doing. Probably more than 10 mph though .
