Car keeps dying, again.
Old 06-09-2008, 08:50 PM
telsonman
telsonman's Avatar
Default Car keeps dying, again.
Well, to follow up on my last post about my car stalling out sometimes, and sometimes it idles up and down on startup, and then might level out if it doesn't cut off. The main stalling occurs whenever I'm driving and have to pop it in neutral like at a stop, or when I push the clutch in, like a simple turn. Anyway, everyone was saying that its the IAC. Well, its only about 5 months old, but I checked it anyway. And of course, there was hardly any fouling in it. So i'm ruling that out.
Is there any possibility that the connector on the iac is bad??? if not, does anyone else have any ideas??? I checked the AFPR, and its fine, no leaks. My fuel is at about 40psi. I'm lost...
telsonman is offline
Old 06-09-2008, 08:51 PM
stang8689
stang8689's Avatar
Default RE: Car keeps dying, again.
Check your TPS voltage
stang8689 is offline
Old 06-09-2008, 09:23 PM
telsonman
telsonman's Avatar
voltage is good, did that about 2 months ago. Could it be a fuel issue, like not enough fuel? I'm running a stock fuel pump on gt40ps, typhoon intake, e cam, and some other stuff.
Old 06-10-2008, 07:58 PM
telsonman
telsonman's Avatar
Could it possibly be a MAF issue??? I'm running a C&L 76mm with24lb sample tubeand i've heard that they don't do well when you upgrade injectors because supposedly the sample tubes are crap.
Old 06-10-2008, 08:00 PM
steel1
steel1's Avatar
Try resetting the base idle?
steel1 is offline
Old 06-10-2008, 08:21 PM
telsonman
telsonman's Avatar
Did that too. My idle is setting at a nice 800-850. For references, i've done tps voltage, idle reset, new iac, fuel pressure at ~40psi, cleaned my maf, ran codes, checked for vacuum leaks, etc. I'm thinking its equipment. Either my C&L is a piece of doodoo, the fuel pump isn't getting enough out, or the electronics in the IAC are fubar.
Old 06-11-2008, 11:33 PM
telsonman
telsonman's Avatar
anyone???
Old 06-11-2008, 11:42 PM
AdderMk2
Banned
AdderMk2's Avatar
check the resistance of your coolant temp sensor while cold, and at operating temp (if you can get it there)
post back with your findings please
AdderMk2 is offline
Old 06-12-2008, 04:53 PM
telsonman
telsonman's Avatar
adder, I forgot to say that I put in a new ECT about 6 weeks ago. Did nothing.
Old 06-12-2008, 04:59 PM
AdderMk2
Banned
AdderMk2's Avatar
try to get your hands on another ECM... for troubleshooting... ofcourse
AdderMk2 is offline
Quick Reply: Car keeps dying, again.
