Trick Flow top end kit question....
Old 06-09-2008, 11:32 PM
dave1170
dave1170's Avatar
Default Trick Flow top end kit question....
Hey guys, I'm going to pulled the trigger and ordered the Trick Flow street heat top end kit. Kit comes with Twisted Wedge aluminum cylinder heads, street heat upper and lower intake, camshaft, roller rockers, pushrods, gasket kit and double roller timing chain. So, the questions are, what size TB and MAF should I go with? Also, what size injectors should I go with? I already have stock block and internals, Mac equal length headers, Mac o/r h pipe and 40 series flowmasters, Walbro 255 fuel pump, MSD Coil, MSD distributor, MSD wires and 4.10 gears. Will my Mac headers work with the Trick Flow heads? What plugs should I use? Should I have a custom tune to get the most of this set up? I know this is a lot to throw at you guys, but all info. would be greatly appreciated! P.S. Also ordered the TKO 600 My wife is going to divorce me.....lol
dave1170 is offline
Old 06-09-2008, 11:45 PM
5pointslow91
5pointslow91's Avatar
Default RE: Trick Flow top end kit question....
u should def get a tune after all that, ur forgot 2 buy the Super Charger
5pointslow91 is offline
Old 06-09-2008, 11:47 PM
dave1170
dave1170's Avatar
Thinking about that later on, will the Trick Flow kit support a super charger?
dave1170 is offline
Old 06-09-2008, 11:56 PM
5pointslow91
u buy a centrifugal SC. n remember, ur MAF should correlate with the size of ur fuel injectors
Old 06-10-2008, 12:03 AM
dave1170
dave1170's Avatar
Thanks 5pointslow91, appreciate the info. mjr46, what is your input on this? I've seen many of your posts and you obviously have a ton of knowledge on our cars!
dave1170 is offline
Old 06-10-2008, 12:53 AM
primetime5.0
primetime5.0's Avatar
you dont need some custom tune to make the most out of the combo, I have a 347 with the only adding fuel on the dyno as my tune
primetime5.0 is offline
Old 06-10-2008, 01:01 AM
jtmustang
jtmustang's Avatar
your gonna want some kind of tune.
and 70 mm tb 24 % injectors and a 75mm maf will all be plenty for this and a little room to grow.
jtmustang is offline
Old 06-10-2008, 01:35 AM
primetime5.0
okay to the dyno, check air fuel, adjust accordingly.. now your tuned.... you really dont need some special chip
Old 06-10-2008, 06:51 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: dave1170
the trickflow kit tends to produce 280 to 290 rwhp which is okay but if you piee together your own kit you may save a few dollars and make more hp...but if you just want everything to show up on your doorstep at once then the trickflow kit can provide that....and the kit can support a supercharger to a degree ..just depends how much boost you wanna run..you'll reach a point where the fuel system will need upgrading as the kit will use most of the stock inj potential not leaving much room for the supercharger..and a tune is always a good thing
mjr46 is offline
Old 06-10-2008, 03:39 PM
dave1170
dave1170's Avatar
Thanks for all the info. everyone! Much appreciated!
dave1170 is offline
Tivo304
08-28-2023 12:19 PM
Dragonus18
09-09-2015 01:21 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
TimeLord101
09-04-2015 09:27 AM
Choppertwo
3.7L V6 Technical Discussions
08-18-2015 02:21 PM
Quick Reply: Trick Flow top end kit question....
