valve/piston clearence
Old 06-13-2008, 03:14 PM
jkrum10238
jkrum10238's Avatar
Default valve/piston clearence
i have a stock 87 i wanna put a cam with .533 int and .544 exh do i have clearence
jkrum10238 is offline
Old 06-13-2008, 03:25 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: valve/piston clearence
lift is not the determining factor in PTV clearance... but Yes, you will end up having to check it, and more than likely have to clearance it
AdderMk2 is offline
Old 06-13-2008, 03:40 PM
jkrum10238
jkrum10238's Avatar
heres the link http://store.summitracing.com/partde...p;autoview=sku
Old 06-13-2008, 03:56 PM
Joel5.0
Joel5.0's Avatar
With the Intake opened .050" @1° BTDC and Exhaust opened .050" @5° BTDC (cam degreed and installed to specifications) during the overlap (when PtV occurs)....... most likely not, but you need to check anyway.
Joel5.0 is offline
Old 06-13-2008, 04:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^ what he saidyou'll need to clay the pistons
mjr46 is offline
Old 06-14-2008, 01:04 AM
5spd GT
5spd GT's Avatar
As stated, peak lift is nota factor for piston to valve clearance.
There is no way to go off lift numbers to see if you will "most likely have clearance problems."
I had .560"/.556" for my camshaft, with stock pistons. No clearance problems whatsoever.
Anyways, advancing or retarding the camshaft can gain you a bit...although it compromises your performance and powerband.
Advancing the timing opens the intake sooner and closes the exhaust sooner. That will gain you some clearance on the exhaust valve, but you will lose clearance on the intake valve. Retarding the cam causes the timing to open the intake valve later, and closes the exhaust later. You'll gain clearance on the intake, and lose clearance on the exhaust. So changing the cam timing won't result in increasing clearance on both valves.
You need to see which one you need most...
Keep in mind, adjusting either way can shift the powerband +/- ~ 200RPM that direction...
The general rule of thumb is .080" on the intake side, and .100" on the exhaust side.
The exhaust side needs a little more clearance due to a couple reasons:
- Piston chasing the exhaust valve as it is closing (spring has less control).
- Heat expansion
- Chain stretch(retards the camshaft)
5spd GT is offline
Old 06-14-2008, 08:14 AM
jkrum10238
jkrum10238's Avatar
im gunna call crane and see what they say, let them do the hard work haha
Old 06-14-2008, 08:26 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: jkrum10238
Do you think Crane personnel will check PtV for you?...... or do you expect a "PtV certificate" for that cam?
Again, most likely it won't have a problem but you need to check..... or install it, crank the engine and cross your fingers.
Joel5.0 is offline
Old 06-14-2008, 01:39 PM
uedlose
uedlose's Avatar
ORIGINAL: Joel5.0
perfect anwser YOU NEED TO CHECK
uedlose is offline
Old 06-14-2008, 02:26 PM
mjr46
mjr46's Avatar
personally I like to know I'm good before I crank a new set up so I don't have to cross my fingers= check ftw
mjr46 is offline
Ninety5five0
10-14-2006 10:27 AM
casinohijack
07-24-2006 09:27 PM
mustang519
02-14-2006 11:10 PM
87GTHO
07-29-2005 02:27 AM
miglet
07-15-2005 12:26 AM
Quick Reply: valve/piston clearence
