water neck gasket
water neck gasket
Gotta change my water neck gasket on my 93GT, did this once a long time ago and I remember it is a pain because of the distributor. Any body have any tricksto make it easier? Don't really want to pull the distributor, it's the drivers side bolt that is the killer.
RE: water neck gasket
it can be a little tight but not all that bad.. no real tricks to it..just remove the bypass hose and 2 bolts and pull it off......just grab a new gasket and t-stat and lightly coat it with rtv for a sure seal and reassemble
best way to make sure the t-stat stays in place is to rtv the waterneck put the t-stat inplace on it and then put the gasket on and let it dry enough so you can put the housing back on with out the stat falling
jwog666
12-27-2021 08:09 PM
