Question About Push Rod Length.
Old 06-13-2008, 10:00 PM
Explosive
Moderator
Explosive's Avatar
Default Question About Push Rod Length.
Alright, we're measuring for our pus rods. But we're new to this so I had a question. We put the rocker on and all that and rolled it over. We colored the top of the valve stem with sharpie to see how much area the roller is covering.
Heres' what we got, the worn away area in the middle of the valve is how much it traveled. Does it look ok ?
We ended up with a 6.25" push rod length.
Incase it matters, it has an E-cam, AFR 165 heads. Comp Cams Ultra Gold Roller Rockers.
~Thanks.
Explosive is offline
Old 06-13-2008, 10:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Question About Push Rod Length.
6.250 is stock length and generally you should be checking with a solid lifter or a converted stock one to solid to view entire travel length..but looks good
mjr46 is offline
Old 06-13-2008, 10:10 PM
Explosive
Moderator
Explosive's Avatar
OK, so what we have looks ok ?
Sorry if I sound stupid but it's the first time either of us have done this.
Old 06-13-2008, 10:36 PM
mjr46
mjr46's Avatar
yeah looks good.......travel should remain in center 1/3 of stem tip and it looks like you have it...are you using the stamped steel rockers??
mjr46 is offline
Old 06-13-2008, 10:53 PM
Explosive
Moderator
Explosive's Avatar
Alright, thanks.
Using Comp Cams Ultra Golds, they're anodized Aluminum.
We got the heads torqued down tonight so we were measuring for the pus rods, heres a couple pics of the motor as it is now,
Old 06-13-2008, 11:08 PM
mjr46
mjr46's Avatar
looks nice!! what's the build??
mjr46 is offline
Old 06-13-2008, 11:34 PM
Explosive
Moderator
Explosive's Avatar
Thanks
Heres a link to FEP, Click the link that thread, I've never really brought the build to 5.0 I've always kept it OT I'm not sure why [&:]
Heres a link, also, that link to tippmann has pics on like every page. I take lots of pics.
http://vb.foureyedpride.com/showthread.php?t=61661
unit91
09-15-2015 09:53 AM
rksnow1
09-14-2015 08:46 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
robjh22
Suspension
09-08-2015 12:47 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Question About Push Rod Length.
