Key switch replacement
RE: Key switch replacement
here you go good luck follow this link http://www.autozone.com/shopping/rep...00c152800697df
It's pretty simple. Remove the plastic cover around the column. Turn the key to the run position. Look under the column, you'll see a small hole. Take a pin punch or something small enough to fit in the hole and push upward on the pin. Then pull the lock cylinder out. Install is just reversed. It's very easy.
zanemoseley
09-06-2015 12:58 PM
