Cap and rotor help! FAST!
RE: Cap and rotor help! FAST!
ORIGINAL: 86whitepony
well if i asked something elementary then ya i would................ i mean maybe it's just me but i learned how to do that when i was 7. and i got blasted plenty of time when i was a newb.
ORIGINAL: PRO50SC
Don't be a dick. The guys asking for help. Would you like the same responses when you need help?
if you can't change a cap and rotor, you shouldn't be able to own a mustang ,much less a COBRA
ORIGINAL: bdptcob
So he should trade his cobra in for a gt so he can learn how to do the exact same thing?
ORIGINAL: redpony88
sure you may need to learn but NOT on a cobra!!! learn on a gt! there's alot more out there so it's not so horrible if something gets messed up, a cobra is a much rarer car. so in all honesty, if you cant change a rotor.... then you shouldt even touch that car. it's about the easiest thing to change..........
Wow, you guys must really be great techs if you get your jollies ragging on someone that asked a simple question. So he's new to what he is doing, so what. Asking questions is how you learn. Maybe the rotor is the o/e and never been changed. I know for a fact they can be very hard to remove sometimes. Maybe he figured he would ask instead of taking a chance on breaking something. But I bet none of you geniuses thought about that huh[&:]? You guys must be ASE master techs (yeah I doubt it), I suggest showing some respect to your fellow stanger and keep the smart guy comments to yourself.
Thanks
Thanks
ORIGINAL: redpony88
actually i am ase certified....... so dont be so cocky....
so what if i dont like when someone asks a dumb question
I think you are the one who's being cocky judging from your responses.[&:]
Adder and I have spoken don't you worry about that and he has been on P/A before because of it. That's where you're headed if you keep up. My suggestion, drop it and be a nicer member to those that don't know as much as you. That's what forums are here for, to help others and learn.
Thanks
Thanks
Lol all this arguing and I haven't seen an answer yet [8D].
I don't know how far you got but you basically just unclip the metal clips on the cap, pull it off, and lift the rotor right out. It should be pretty easy since it just slides right onto the shaft. There shouldn't be anything causing it to stick unless someone glued it in or something. It is pretty much the easiest thing you can do with a car so if you are having trouble I'd try and get a maintenance manual and look through that before tackling any other projects on the car.
