Strange noise in rear?
Old 06-16-2008, 06:34 PM
hemi_04d
hemi_04d's Avatar
Default Strange noise in rear?
This relates to my bearing thread but here goes.
When it is wet out or I go through a puddle I get a knocking sound coming from the back passenger side tire. I thought wheel bearings, replaced those and it still does it. I know the quick fix would be not to drive it when its wet out But I would like to fix whatever it is that is wrong with it. Any ideas?
hemi_04d is offline
Old 06-16-2008, 06:39 PM
droptop302
droptop302's Avatar
Default RE: Strange noise in rear?
Rear drum or disc?
droptop302 is offline
Old 06-16-2008, 07:22 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Have you rotated your wheels to see if the sounds travels with the wheel??
projectresto83 is offline
Old 06-16-2008, 07:24 PM
droptop302
droptop302's Avatar
It only does it when its wet out?
Old 06-16-2008, 07:32 PM
hemi_04d
hemi_04d's Avatar
Drums in the rear. I checked and double checked and those are put together properly. No I haven't rotated the tires but I will try that tommorow.
Yes the only time it does it is if its raining or I go through a puddle, but its not constant, it is only when I push the brake pedal.
hemi_04d is offline
Old 06-16-2008, 07:37 PM
AdderMk2
Banned
AdderMk2's Avatar
sounds like your drums are warped internally... swap them and see if the sound follows
AdderMk2 is offline
Old 06-16-2008, 07:40 PM
droptop302
droptop302's Avatar
That's strange only does it when it wet out. If it did it all the time i would say the drum is out of round (meaning all the time when you hit the brakes) Try swapping the drum from one side tothe other see what happens...
Old 06-17-2008, 07:18 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: droptop302
Is there an echo in here???
AdderMk2 is offline
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
robjh22
Suspension
09-08-2015 12:47 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Strange noise in rear?
