turn signals won't work
Old 06-16-2008, 11:05 PM
telsonman
telsonman's Avatar
Default turn signals won't work
Well, they haven't been working for about 2 weeks. I've tried replacing the multifunction switch, and checked and rechecked the wiring going to the multifunction switch and all under the steering column. And yes, the fuse is still good. I had this problem before, and replacing the switch worked, but now thats not the answer.
any help???
telsonman is offline
Old 06-16-2008, 11:31 PM
90lxstang
90lxstang's Avatar
Default RE: turn signals won't work
i had this problem recently and replacing the ignition switched fixed the prob. my a/c was also out at the time and the new ignition switch fixed both.
90lxstang is offline
Old 06-17-2008, 01:13 PM
Hawk
Hawk's Avatar
Just checking, but when you say the turn signal doesn't work, do you mean when you put the signal on it what??? Does it not blink on one side? Does it light up on both the front and rear turn signal bulbs solid? Basically the easy things that will cause your turn signal to stop working is 1) you have a bulb out or 2) you have a bad turn signal flasher. Both fixes for under $10.
Hawk is offline
Old 06-17-2008, 05:44 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Make sure that the sockets for the bulbs are clean and not corroded. I had one bulb that wouldn't work until I cleaned the years of corrosion out of it.
projectresto83 is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
kdryan
08-21-2015 04:01 PM
KEM Motorworks
08-14-2015 10:13 PM
cema93
08-10-2015 09:35 PM
Quick Reply: turn signals won't work
