car wont run! help
car wont run! help
when i go to start my 89 gt it cranks...trys to run and shuts off.i noticed when i turn the key you dont here the fuel pump whine, but when i crank i have 42lbs of fuel pressure...i also check spark an i have it and i checked the injectors with a noid light and it lights up..the inertia switch is good and i also tried swapping tfi modules and it does the same thing... any suggestions? or so i have a huge wiring problem somewhere?? thanks
RE: car wont run! help
It may be an ignition switch ?? I know mine did something like like w/ the fuel pump and i thought is was the relay. Turned out to be the relay box where the actual relay plugs into. These are known to go bad. You can get one at the junk yard or go get a new one at napa for like $10. These relay boxes where the relay goes into have 2 grounds and like 2 hots. One hot constantly and one hot w/ the key forward so to speak. Hope this helps you out in your case.
ok so i chekced all the fuseable links and they are good...the new ignition switch didnt fix the problem...the car wont stay running unless i hold the key in a certain spot( where the starter disengages) the tumbler was replaced about a month ago and i noticed yesterday that the key turns foward alot more...is itpossible the tumblers f*cked up.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
