Underhood Wiring Project
#31
It's all pretty straight forward, nothing hidden or anything really to worry about.
What I have in my write-up worked for me and probably hundreds of other people but that's not to say it will work exact for you, use it as a guide line and come up with something better is my best suggestion.
I only have 2 suggestion that may help you a little more.
(1) Before you start thinking about cutting any wires make sure that you done all that you can do to not cut the wire. Possible a different location is the first thing that come to my mind.
(2) As long as you have the old plastic shielding off main harness which expose the wires to the passenger side and drivers side try pulling those wires to the side the wires need to go, either drivers side or passenger side. This helps in lengthening those wires so that later you shouldn't need to cut and lengthen any wires.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
