buying afr 165
Old 06-19-2008, 09:51 AM
tw3ak
tw3ak's Avatar
Default RE: buying afr 165
ORIGINAL: TrickFlowTech
Just a question, but why are not going with the Twisted Wedge heads?
Thats a good question I have a question though... I want to get some TW 170s. Will they be ok with an E cam with stock bottom? I want something I can use on my stock block untill I get my 347 going. Would the 170s be aite for a 347 build? Thanks!
tw3ak is offline
Old 06-19-2008, 10:03 AM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
ORIGINAL: ucjattriskey510
im thinkin of purchasing afr 165 today...does anyone know a good place to buy it?? and im thinking of combining this with trickflow street intake... is this a good combo?
Oddly enough, I was going to ask that same question....But I see you've already got it handled.
Sidewayz6.0 is offline
Old 06-19-2008, 12:12 PM
5spd GT
5spd GT's Avatar
I prefer AFR heads because they are a FULL CNC head and have lighter valvetrain (8 mm valves (not 11/32) and lighter springs).
The TFS heads are nice, but I prefer the AFR heads. The port finish is just better.
5spd GT is offline
Old 06-19-2008, 01:21 PM
jtmustang
jtmustang's Avatar
yeah the port finish is better as the afr's come cnc machined and the regular 170 tw's dont but then u can buy trickflow 185 cnc 'ed heads that will outflow afr 185's[:'(]
and to the op about the 170 heads on there car with the e cam until u can stroke it yes they will work for a stroker ,as i would get some port work done when u swap over to the stroker and get the track heat heads with the dual valve springs or throw on a set of anderson motorsports hi rev springs as i did and call it good. until u up the motor a bit.
jtmustang is offline
Old 06-19-2008, 01:44 PM
TrickFlowTech
Banned
TrickFlowTech's Avatar
Good answer.
Also the 170 TW head will out flow that 165 cnc'd head.
ORIGINAL: jtmustang
TrickFlowTech is offline
Old 06-19-2008, 02:09 PM
jtmustang
jtmustang's Avatar
Also the 170 TW head will out flow that 165 cnc'd head. .................................................. ......
haha to the other people that say that the afr's are better and flow more i got the trickflow tech guy behind me..........[8D]
Old 06-19-2008, 02:16 PM
5spd GT
5spd GT's Avatar
Yes, it outflows on the intake side, but not the exhaust side.
The TFS cylinder head is a shorter runner, which creates less piping, which helps better flow (minus the intake runner).
The TFS is a good cylinder head, but I prefer full CNC and a lighter valvetrain like the OEM is now going!
Flow is not everything. Per square inch, the AFR 165 flows better in the upper lift ranges, which is where power potential occurs.
5spd GT is offline
Old 06-19-2008, 02:33 PM
68CSTANG
68CSTANG's Avatar
By tm this will be a 5 page thread...the never ending battle
68CSTANG is offline
Old 06-19-2008, 02:35 PM
BlessedHellride
BlessedHellride's Avatar
TrickFlowTech,
What's the biggest cam that can be run on a stock bottom end with the 170 heads. And what are the cost of these heads from Trick Flow or would I have to go through a vendor somewhere to get them. Can you make deals off of here for forum members? I will be in the market for a set of small heads for a stock 89 that I'm gonna do some minor upgrades to.
BlessedHellride is offline
Old 06-19-2008, 03:14 PM
jtmustang
jtmustang's Avatar
i was told that the biggest ots cam u can run is one with no more than .540 of lift
i bought mytwisted wedge heads from amp performance for 1150 to my door
Quick Reply: buying afr 165
