gt40 specs
RE: gt40 specs
there not the p's but i have gt40 heads, typhoon upper and lower just having problems deciding on a cam i just dont get the lift and duration stuff yet still learning all that stuff
RE: gt40 specs
as u see there is hardly a difference in the 2 gt 4o heads just a little more flow on the exhaust side thats why i would atleast open up the exhaust side a little and the bowls if i was u to get alll u can out of those heads or if your on a budget 1.7's but what cam are u thinking about?
RE: gt40 specs
well i was told by a friend that i can upgrade the lifter and rockers and keep the stock cam but i want that cam sound, i was thinking tfs 1 or an e or x cam my friend said lunati but havent heard much about those there probably up there in price
RE: gt40 specs
man what are u doing with the car is it a daily driver or close to or strait out track/weekend warrior car?
as if its just a dd i would l would throw in a tfs 1 atleast if u are on a budget its a decent priced cam as its like 160 new or cheaper on ebay or?
and if its a track car i would look into something a little more aggressive.,something also to think about is if your using the stock block and pistons then u will have to watch ptv clearance for the cam and u wont be able to go to big without a custom cam and that will cost 300-400 bucks.also if u are upping the cam upgrading the valve springs in the heads is a must if your staying with the stock cam u'll be alright but still will want to check/replace the stock gt 40 springs.
