codes again
Old 06-20-2008, 09:47 AM
bertt
bertt's Avatar
Default codes again
well my dad just went out and bought a snapon code reader so i plugged it in and came up with awhole bunch of stuff, here we go!
so for koeo i came up with tp/filp sensor out of range, thermactor divert or bypass circuit, and for continuis memory codes i came up with profile ignition pickup erratic
for koer i came up with ccc/ss4 circuit fault/ thermactor air inop, and thermactor air system not working
what is the filp sensor and where is it located? what is the thermactor circuit? and how do i fix the profile ignition pickup erratic?
and what is the ccc/ss4 circuit and where is it located? why is my thermactor not working lol i dont even know if it even would make a diff? thanks
bertt is offline
Old 06-20-2008, 10:31 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: codes again
do you still have emissions? thats what those have to deal with.
FivePointOhh is offline
Old 06-20-2008, 11:21 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: bertt
tp may refer to throttle position sensor, and PIP signal refers to the stator/pick up in dizzy..= could be bad and or tfi module.......and thermactor air refers to smog pump and or system controls that regulate air from pump into exhaust= used on cold starts to warm up cats quicker....have you removed smog equipment??...personally I'd clear codes and see what codes may or may not come back..are you having any drivability concerns with car??
mjr46 is offline
Old 06-21-2008, 09:22 AM
bertt
bertt's Avatar
just idlesurging but thats from the cam so ya lol umm i has a hard time stating sumtime, and i have only removed cats so yu think i should just delete smog puimp and all that bs? i replaced the throttle position sensor, and what do you think i should do about the pip signals? ive cleared them but the same ones come back so?just ignore the thermactor sh*t?
bertt is offline
Old 06-21-2008, 10:40 AM
mjr46
mjr46's Avatar
the thermactor air system is doing you no good with cats removed so just ignore those codes or remove smog system if you don't have emissions..for the pip signal you could try replacing stator/pick up in dizzy and or tfi module
mjr46 is offline
Old 06-21-2008, 11:12 AM
frankbullitt
frankbullitt's Avatar
Dont wait to long to fix the PIP. The surge from time to time will lead to the car turning off randomly and can lead to the stang not wanting to start. Which is where im at.as for the other stuff, clear the codes and see what comes back
frankbullitt is offline
Old 06-21-2008, 11:28 AM
mjr46
mjr46's Avatar
he did clear the codes and the PIP keeps coming back^^^^^
mjr46 is offline
Old 06-21-2008, 12:59 PM
frankbullitt
I meant see if the other codes come back. The PIP code isnt goin anywhere till its resolved and fixed. praying the codes dissappear get you know where haha thats why i'm stuck ridin my motorcycle everywhere now
Old 06-21-2008, 01:42 PM
mjr46
mjr46's Avatar
ORIGINAL: frankbullitt
like I said he has done that and all the other ones keep coming back including the Pip codes
mjr46 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: codes again
