EFI TO CARB HELP
EFI TO CARB HELP
Im going carb. How does this setup look? I want to make sure everything will work and compatible. It's going on a 306 w/ stock heads untill i get some TW's.
Demon 650 w/ mech seconds
Performer RPM Air Gap intake
MSD 6AL Ignition
MSD-8598 Distributor (steel gear)
MSD-8223 Blaster 3 coil
AEI-13301Aeromotive 3-60psi (is this overkill? im running an efi pump)
Is this all compatible? Is there anything else I should grab for the swap? Am I missing anything?
MSD 6AL Ignition
RE: EFI TO CARB HELP
Demons site recommends mech for manual.. i dunno??
I will look into Crane. I just want something with a rev limiter. Nothing fancy. It would always be nice to save a little money.
ORIGINAL: mjr46
for the regulator a holley one will work fine psi on a carb stang is best set to 5-6.5 psi depending on build and use
this is all I have with a holley b lue pump..not sure what you mean by cheap but 27 beans ain't much
http://store.summitracing.com/partde...p;autoview=sku
