which one
Old 06-22-2008, 01:18 AM
ucjattriskey510
ucjattriskey510's Avatar
Default which one
Which of this two is better for my 95gt?? smog legal? i dont want to notch d pistons..
BOTH AFR heads
SB-Ford Outlaw Street Cylinder Head [*]165cc Intake Ports[*]Stud Rocker Arm Mounting[*]58cc Combustion Chambers[*]69cc Exhaust Ports[*]1.450' Hydraulic Dual Valve Spring with dampner[*]120 lbs. Seat Pressure[*].550' Max Lift[*]Sold in Pairs
OR
SB-Ford Outlaw Street Cylinder Head [*]165cc Intake Ports[*]Pedestal Rocker Arm Mounting[*]60cc Combustion Chambers[*]69cc Exhaust Ports[*]1.450' Hydraulic Dual Valve Spring with dam[*]120 lbs. Seat Pressure[*].550' Max Lift[*]Sold in Pairs
ucjattriskey510 is offline
Old 06-22-2008, 08:00 AM
FLcracker9
FLcracker9's Avatar
Default RE: which one
The stud mount head will give you a little more compression based on the combustion chamber sizes you provided, other than that, they are the same heads with 2 different rocker arm mounting systems?
FLcracker9 is offline
Old 06-22-2008, 08:02 AM
stang8689
stang8689's Avatar
I would get the stud mount
stang8689 is offline
Old 06-22-2008, 09:01 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
go stud mount afr heads ftw!!
mjr46 is offline
Old 06-22-2008, 09:23 AM
ucjattriskey510
so if i go for the stud mount, can i supercharge it later on? cuz im planning to go with vortech.
Old 06-22-2008, 10:02 AM
ctgreddy
ctgreddy's Avatar
if your planning on supercharging it get the stud mount but get a higher combustion chamber size, like something higher than 60cc
ctgreddy is offline
Old 06-22-2008, 10:25 AM
jtmustang
jtmustang's Avatar
dude i already told u in your last thread stud mounted and tw's
jtmustang is offline
