Car is running terrible
Old 06-25-2008, 09:11 PM
Joel5.0
Joel5.0's Avatar
Default RE: Car is running terrible
ORIGINAL: bharv29
ok i put the stock computer back in and it crunk up and idled fine the only problem with the stock computer was it pulls timing when it is time to shift the aode and bucks the car so im starting to think that the t4mo computer is bad.
You have an auto SN95 ECM, with the neutral switch permanently in-neutral + all the AODE solenoids failure codes logged....... the ECM is not "shifting" anything..... need to check what else is causing that problem. Ask the EEC.
Joel5.0 is offline
Old 06-25-2008, 10:48 PM
bharv29
bharv29's Avatar
Yes i have both computers the auto and the manual. The auto runs fine at idle but bucks when you try to go and the manual computer is the one giving me all the problems.
bharv29 is offline
Old 06-26-2008, 10:44 AM
cholericfc
cholericfc's Avatar
for the fox bodies..... i have a 90 with aod... converted to t5 and by leaving the old aod computer in it...it actually runs better ETAs... but you wouldn't notice.
cholericfc is offline
djbigskrilla
09-20-2022 01:04 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
J.casone400
08-07-2015 08:40 PM
Quick Reply: Car is running terrible
