breaking up at 2500rpm??
RE: breaking up at 2500rpm??
ORIGINAL: 89mustangfive0
ok..i also noticed wiggled all the wiring that goes to the starter relay near the battery, like all the fuseable links and i noticed it hasnt broke up, is it possible i just have a wiring issue?
i tried to clear codes and run but wont work...my dad said its possible my 1 month old wires are no good...it couldnt be a nadd dizzy or fuel pump going bad oculd it? i notice its worst when im at a stop sighn and then i take off on a turn or at a dead stop..feels like the car dont wanna go
you need to find which cylinder is misfiring..while running pull plug wire with insolated pliers and see if spark jumps off wire on to plug to eliminate wire /cap issue....when pulling a wire you'll notice the engine load change= that cylinder is firing..when you pull one where you notice no load change..that will be the cylinder not contributing= pull plug and inspect..if okay perform a compression test on that cylinder/s
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
ccdguy
09-19-2015 05:20 PM
