I need help w/ H-Pipe install
OK - I installed a BBK O/R H-Pipe. I have 2 chamber Flowmasters which have been on the
car for awhile but in good shape. BBK shorty equal length headers,Ford Motorsport E-303 cam.
Heres my problem. Finally got the new pipes on. They seemed to line up good. In fact the
little pipe even fit (smog pump pipe). I tightened everything up equally, a couple of times,
everything seems good & tight. When I start the car it's really loud.... but I hear as much sound (flutter-like) coming from the point where the headers hook up to the pipe.( both sides). It doesn't sound bad but it doesnt have that "growl" like I think it should. It kind of sounds like a drag car when its idling (because of the cam?) but it doesn't sound like ANY of the clips Ive researched. Its really lound inside the car and a lot of the noise is up front. If its leaking bad would it be a good idea to take it to a shop where they can make sure there are no leaks? Will a muffler shop work on it now that I pulled the cats off? I'm stuck-please HELP.
thanx
thanx
RE: I need help w/ H-Pipe install
well as shops go..u just gotta check cuz one place my buddy took his camaro n it didnt have any cats n they wouldnt touch it unless he paid them the money for a cat n they replaced it...but my other buddy took his mustang in n had them put on a new off road h n they told him they werent responsible but they did it...as for the problem..u made sure that the pipes arent hitting the body anywhere right? because i have that problem once with something out of adjustment and it made it really loud inside..the leak sound u think u hear..is it a ticking sound?..and u should be able to check somewhat urself for leaks..feel around and get on the ground n listen as close as u can at the joints..
i had the same problem with mine, it took about three tries to get it to line up right, my friends stang had the same issue, and yes it sounds like a drag car cusof the cam, straight piping makes it way too loud, kind of annoying. although your cam isnt anything big it still makes it sound real beefy idling, i have the same cam, same headers and i usedto have the OR H pipe as well, i have two chamber flowmasters too, so its all the same, i'll see if i have a vid so you can more or less see what its suppose sound like without the leaks
ok right now my car has bbk shorties the same cam as you the same h pipe same mufflers and everything,i couldnt find a video where its idleing so i went out with my phone and took one and sent it to my email. photobucket wont work for me right now but i can email it to you, the quality is really really ****ty but you can still hear it pretty good
09-10-2015 08:39 PM
