Surging idle & bumpy on decel
Old 06-30-2008, 09:04 PM
poopaloop
poopaloop's Avatar
Default RE: Surging idle & bumpy on decel
bump, i have the same detachted mystery vaccum hose^^^^^
poopaloop is offline
Old 06-30-2008, 09:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
those are for the emissions controls and if the source vaccum is detached and plugged you'll be fine but all you need to look for vaccum leaks is a can of carb cleaner and to pull codes GOOGLE..... DIY koer test
mjr46 is offline
Old 06-30-2008, 09:41 PM
88fox50
88fox50's Avatar
as mjr said, its most likely a vac leak....its a very common problem...i had it myself ...i even posted a vid that looked just like yours ..lol. after i replaced the IAC and the TPS and cap/rotor/plugs, fuel filter....it still did it...found it to be the MAP sensor vac line from the back of the upper plenum ..
88fox50 is offline
Old 06-30-2008, 10:01 PM
poopaloop
poopaloop's Avatar
ahhh icic, i was just wondering where the h*ll that line attatches too then, i have the line plugged b.c i couldnt find the source but mines still surging (worse than 306stangs). pix of the source? trying to narrow it down as well
annnnd i also apologize for stealin the thread unintentionally :P
Old 06-30-2008, 10:39 PM
88fox50
88fox50's Avatar
dont hav pics yet but its up under the back side of the upper intake...
88fox50 is offline
Old 06-30-2008, 11:18 PM
poopaloop
poopaloop's Avatar
that vac line stretches that far? ill have to take a looksy tmrw mornin, thx 4 the info
Old 07-01-2008, 12:50 PM
306stang
306stang's Avatar
ORIGINAL: mjr46
Where is the source vaccum? could this possibly be causing my problems.
I searched up DIY koer test and found this
http://myshifter.com/joel50/EECTEST.html
Guess i need a new voltometer.
306stang is offline
Old 07-01-2008, 12:51 PM
306stang
306stang's Avatar
ORIGINAL: 88fox50
I'm sure I have a bad sensor, I can grab that from the dealership right?
306stang is offline
Old 07-01-2008, 12:53 PM
306stang
306stang's Avatar
ORIGINAL: 88fox50
Is this something I can do myself and grab the parts from the local store?
306stang is offline
Old 07-01-2008, 05:10 PM
306stang
306stang's Avatar
Well I stopped at the store to pick up the MAP sensor. Plugged the new one in and to my suprise it idled fine. I let it idle for about 5-10 min, Which i was guessing enough time for the thermostat to turn on and it seemed fine.
Rev'd it up a time or two and everything was normal.
Then I dropped it into reverse and STALL.
I heard no grinding, NOTHING, it just cut off.
The car has had a history of dropping the RPMs extremely low then come back up real quick when put into reverse and it's stalled out on me into reverse a time or two in the past 5 months or so.
I've suspected a broken transmission mount because of the thumping on deceleration but i've never got it checked out.
Could an extremely broken transmission mount (or two) cause the motor to cut off?
It seems as if the transmission has alot of play when i take it in and out of gears. (we're talking AOD)
HELP!
306stang is offline
Quick Reply: Surging idle & bumpy on decel
