Surging idle & bumpy on decel
Old 07-01-2008, 08:00 PM
  #21
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Surging idle & bumpy on decel
on the intake there are various ports ...these I refer to a source vaccum points because they provide vaccum to various components such as emissions controls, brake booster and pcv system.....with a can of carb cleaner spray all vaccum hoses slowly listening for a change in engine idle and spray all intake mating/gasket areas and egr calve and anything that carries vaccum..when idle changes you have found a leak..= fix it and look for the next if any exist
mjr46 is offline
Old 07-01-2008, 09:34 PM
  #22
88fox50
88fox50's Avatar
ORIGINAL: mjr46
i never knew that. but its painfuly logical...[sm=headbang.gif]
88fox50 is offline
Old 07-02-2008, 12:21 AM
  #23
306stang
306stang's Avatar
why is it only hapenning in reverse?
can bad tranny mounts cut off the motor if the tranny moves too hard?
306stang is offline
Old 07-02-2008, 03:33 PM
  #24
306stang
306stang's Avatar
anybody?
306stang is offline
Old 07-03-2008, 09:43 AM
  #25
306stang
306stang's Avatar
306stang is offline
Old 07-03-2008, 06:43 PM
  #26
aode08
aode08's Avatar
ORIGINAL: 306stang
Heres a video of it idling after 10 min. Once the check engine light stays on it will smell rich.
If i'm out driving it the light will come off and it drives just fine, but once its idling all the problems start up again.
http://s22.photobucket.com/albums/b3...t=DSCN2947.flv
Can i get the IAC ordered at the ford dealer?
CHECK ENGINE LIGHT
now why do you have to send your car in for that?
aode08 is offline
Old 07-09-2008, 09:54 PM
  #27
306stang
306stang's Avatar
ORIGINAL: aode08
ORIGINAL: 306stang
CHECK ENGINE LIGHT
I'm not sure I understand your question.
I cleaned out the electronics on the throttle body and replaced the IAC but now It will idle fine until i put it into reverse in which the rps will drop low, either stall, or jump up and then start to surge from 900-1500 sometimes higher. and when I put it back into park it will continue to do the same thing.
The problem doesnt happen if I just leave it in park or drive. As soon as I put it in reverse it acts as it use to before the IAC replacement.
306stang is offline
Old 07-10-2008, 10:51 AM
  #28
306stang
306stang's Avatar
is there indeed a connection with my idle problem and my reverse gear?
I'm probably just going to replace all my vaccum lines and go from there.
306stang is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: Surging idle & bumpy on decel
