Lower Springs VS Drag Springs
RE: Lower Springs VS Drag Springs
Well i plan on installing a tubular k-member with coil over conversion so i dont wanna buy a full spring set. What do you think of the moroso trick springs?
those springs transfered awesome. i personally had to jack them up. my set up was a aje tubular k-member frpp a-arms the eibach drag springs and those weight jackers. you have to pull the quad shocks but after i did that, it felt awesome when i punched it
ORIGINAL: One Bad ****
Did you run it with them raised or dropped? How'd it hook with those and the drag springs?
ORIGINAL: redpony88
wow... throw some eibach drag springs on it and get these rear control arms, they're called weight jackers, you can raise it 2inches or drop it -1 inch from stock height. i put them on my fox with those drag springs and it felt awesome
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
