no compression
Old 06-29-2008, 11:31 AM
tinner7
tinner7's Avatar
Default no compression
Ok, I did something stupid this weekend, I had no comression in my #5 cylinder, so I figured blown head gasket. I spent the good part of yesturday replacing this gasket. I hooked up my tester, and what do you know, no compression. I can think of alot of stuff I should have done before just throwing the motor back together, but hind sight is 20/20. I have AFR heads on, that where new last summer, with roller rockers. I checked the #6 cylinder and it tests fine. I added a little oil to the cylinder and this did nothing. I get 0 compression. Could I have a sticking valve? Bad piston rings? I thought with bad rings, I would get alittle compression, but I get nada.
tinner7 is offline
Old 06-29-2008, 11:36 AM
droptop302
droptop302's Avatar
Default RE: no compression
What made you check it?
droptop302 is offline
Old 06-29-2008, 11:51 AM
tinner7
tinner7's Avatar
white smoke coming from my tail pipes, after the thermostat opened
tinner7 is offline
Old 06-29-2008, 12:01 PM
droptop302
droptop302's Avatar
You should of sent the head to a machine shop.Do a leak down test with both valves closed and see what happens
Old 06-29-2008, 01:25 PM
tinner7
tinner7's Avatar
yeah, hind sight lol, I will drink a few beers, relax and look to tear it all back apart next weekend
tinner7 is offline
Old 06-29-2008, 01:48 PM
woodsy
woodsy's Avatar
valve is open, nearly impossible to have absolutely no compression
woodsy is offline
Old 06-29-2008, 01:53 PM
droptop302
droptop302's Avatar
ORIGINAL: tinner7
Good luck let us know how it goes
Old 06-29-2008, 03:07 PM
ctgreddy
ctgreddy's Avatar
are you sure the rockers just aren't adjusted right?
ctgreddy is offline
Old 06-29-2008, 03:55 PM
tinner7
tinner7's Avatar
ok, here is a update. I went out to the garage and took off my rockers on the cylinder, sprayed alittle wd40 around the valves, let them sit for abit, then took a small deadblow hammer and gave each valve a little tap. Hooked up my compersion test gauge hoseand could hear air being pushed out through the shreider valve in the hose. Put back on my rockers, set them up and adjusted them to specs, and then hooked up the comperssion tester with the gauge. Low and behold, I have compersion. Sometimes it helps for me to just put the wrench down, walk away, think abit, maybe put up a post on my problems, then go back to it with a clear mind. Thanks to you all that responded. I am still alittle concerned about the original problem that lead me to do the compresion test, the smoke coming from my tail pipes after the car has gotten up to temp. This was the only cylinder that tested low, compared to the other seven, so I pulled the head and put in a new head gasket.
tinner7 is offline
Old 06-29-2008, 06:50 PM
1988GTstang
1988GTstang's Avatar
and dont forget the beer it always helps lol
1988GTstang is offline
Quick Reply: no compression
