vacume help
Old 06-29-2008, 04:14 PM
GaryBisiniere
GaryBisiniere's Avatar
Default vacume help
alright so i have the edelbrock performer rpm 2 and i was just woundering where the vacume lines go from the back of the intake?
thanks gary
GaryBisiniere is offline
Old 06-30-2008, 06:09 PM
15austin
15austin's Avatar
Default RE: vacume help
One goes to the fuel pressure regulator, another goes to the vaccume pod thingys by the passenger firewall in the corner of the bay, another bigger one goes to the pvc valve in the back of the intake, the other bigger one goes to the vaccum tree on the firewall beside the map sensor. Hope this helps.
15austin is offline
Old 07-03-2008, 06:22 PM
GaryBisiniere
is there any way to run it without the vacume tree?
Old 07-03-2008, 07:49 PM
ALMOST STOCK
ALMOST STOCK's Avatar
The Vacuum tree acts likeas Distribution Block.
So No you don't need the vacuum tree.
All you need is a vacuum source and a bunch of line running from it to all the different vacuum line locations.
ALMOST STOCK is offline
Old 07-03-2008, 07:57 PM
GaryBisiniere
yea the performer rpm 2 has vacume ports out the back of it. just woundering where to put the lines because i do not have a tree
Old 07-03-2008, 08:00 PM
GaryBisiniere
im new to efi had a carb on my car last year so im not sure where everything is supposed to go
Old 07-08-2008, 02:31 PM
GaryBisiniere
any1?
Old 07-08-2008, 03:46 PM
tncruiser
tncruiser's Avatar
correct spelling is vacuum
tncruiser is offline
Old 07-08-2008, 04:10 PM
redpony88
redpony88's Avatar
just go get a tree from a junkyard, make things easier. that way you dont have to pull a crap load of lines when you pull your upper for anything
redpony88 is offline
Old 07-08-2008, 04:35 PM
GaryBisiniere
ya the guy i bought my intake from already have the lines and fittings on the intake
and its 1 less thing to have in my engine compartment...
Quick Reply: vacume help
