hunting idle.
Old 07-02-2008, 08:49 AM
Mikes5.0
Mikes5.0's Avatar
Default RE: hunting idle.
If you have your original mass air meter, take it off and spray it out with cleaner then use air to blow it out, see if that helps.
Mikes5.0 is offline
Old 07-02-2008, 10:14 AM
cholericfc
cholericfc's Avatar
If you take ur sensor out tho, DON"T DO THAT.... but what he said is good.
cholericfc is offline
Old 07-02-2008, 01:36 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
I chased my idle for a year..........changed vacuum lines, pulled codes, cleaned (and replaced) IAC, and MAF......replaced o2 sensors...........nothing worked.
Threw in an SCT chip, got a dyno tune......my car now idles PERFECT!!!!
Good luck!
CantStopTheFox... is offline
Old 07-02-2008, 01:52 PM
Mikes5.0
Mikes5.0's Avatar
This is true the dyno may be your best bet especially with the 303 cam ypu have.
Mikes5.0 is offline
Old 07-03-2008, 12:03 AM
saocore88
saocore88's Avatar
how do you go about dyno tuning. what do you recomend?
saocore88 is offline
Old 07-03-2008, 08:42 PM
Mikes5.0
Mikes5.0's Avatar
Ive never done it mysellf but after my blower is on ill need tuning too. You need to find a shop with the dyno
Mikes5.0 is offline
2007StangV6
01-28-2016 06:09 PM
TCStangerv6
10-11-2015 05:57 PM
10-07-2015 07:02 PM
mtxplod
08-29-2015 01:43 AM
Quick Reply: hunting idle.
