high idle
Old 06-30-2008, 11:25 PM
jkrum10238
jkrum10238's Avatar
Default high idle
i have an 87 with stock everything besides my exhaust (glass packs and dumps people think its the fastest car in the world haha) i just to the engine out and put it back in with a new clutch and fixed oil leaks. i have a 1500-2000 rpm idle i check the vac lines they dont seem to bad and befor i start replacing them anyone no of any other causes for a idle that high its driving me nuts i miss my low 5.0 rumbling idle
jkrum10238 is offline
Old 07-01-2008, 10:32 AM
redpony88
redpony88's Avatar
Default RE: high idle
check the iac, the tps voltage, timing, and check around the manifold for vaccume leaks, one way is to spray brakelean around and see if idle drops, also stick your hand in around the back and wiggle the lines see if you can make the idle change, one big thing is the pcv.
redpony88 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Drastang
09-30-2015 03:48 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: high idle
