Idle Air Control-All Created Equal?
I am currently looking to replace a bad IAC on my 92 GT. Went to a boneyard and found plenty of 4 cylinder Stangs to rip on off of but was unsure if it would work on my five-o. Would this work??
RE: Idle Air Control-All Created Equal?
ORIGINAL: mjr46
they are cheap enough just go to your local parts store and buy a new one
ORIGINAL: mcarr6262
Ford dealership told me that transmission, year, and engine all matter. Basically that i have to get one from them new.
They operate the exact same. As far as i'm aware there are only two types out of all the cars made. The stepper type (used on gm's) & the fast idle solenoid type (used on most (if not all) efi fords)
I believe the only difference is the plastic plug on the end of it. If i'm not mistaken the 2.3's plug comes straight off, the 5.0's has a 90 degree bend in it.
I believe the plug is the same, just at a different angle... Not sure if that makes sense... Basically it will work providing the plug will fit. (mine is broken off so I just have two wires on one of my cars)
I can check for you later.
09-08-2015 11:50 AM
