Eletrical PROBLEM NEED HELP!!!
[hr]
Well on my way home last night from my game top to get food got out start the car and everything goes haywire, the temp gauge was pinned and its not even connected also the oil pressure gauge is pinned and the volte gauge was at about 8-10, and when i put the e-brake down i lose the tack and the car almost stals and goes to very low rpms and the abs,airbag and some other lights come on, then i take the key out and the warning lights stay on if the e-brake is down. i just took the alternator to autozone and the volt regulator was bad so bought a new one and it passed, come home put it all back together and a little better then went to **** again, only reading 10.3 volts. [/align]
RE: Eletrical PROBLEM NEED HELP!!!
wow... try testing the battery and make sure it's good, also pull the cable to it for awhile and that should clear the computer, hopefully the computer is okay. but once the computer is cleared, see if it does it again
Sounds like a power wire is touching somewhere it shouldn't be. I think this is a situation where you're going to have to trace the wire. I'd start at the ebrake & find out where the wires go to from it.
Anything replaced recently?
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
jaiidutch
09-14-2015 10:29 AM
